Re: Sherman install
Posted by Kirk-NJ on May 14, 2018 at 15:38:15 [URL] [DELETE] :
In Reply to: Re: Sherman install posted by Rick D on May 13, 2018 at 18:08:23:
It's somewhere around 20 or so. Check your repair manual for numbers. I'm out of town so I can't look it up for you. Feel system works ok. You don't want it to tight
If trans is double split don't use any on the Sherman and preload from he rear of trans.
If you don't have excessive wear on the bearings or cups it's likely you could use the same amount of shims. If too loose take the thinnest shim out an go from there.
Kirk
