Re: Sherman install
Posted by John Smith on May 13, 2018 at 16:33:57 [URL] [DELETE] :
In Reply to: Sherman install posted by Rick. D on May 12, 2018 at 21:27:22:
The Sherman install instructions assume itís being done with only a front split where you canít access the rear bearing retainer on the main shaft. If you have the transmission removed completely then doing all the shimming from the rear would be preferred. You have the right idea.
