641 governor spring and throttle arm
Posted by Mike in Michigan on May 08, 2018 at 18:43:16 [URL] [DELETE] :
I happen to notice my governor spring was broke. Tractor had a problem idling low so I thought maybe that was the problem.
Being cheap I put on a spring that was similar in size from Lowes. Still wont idle low.
I decided to put the correct spring on and still wont idle low. However with the correct spring on the throttle lever will not even stay in a low position, wants to jump to high idle like the spring is too strong.
Engine starts and runs great, just does not have a nice low idle.
