Re: 8N cooling
Posted by K.LaRue-VA on May 08, 2018 at 07:19:53 [URL] [DELETE] :
In Reply to: 8N cooling posted by Tommy on May 07, 2018 at 17:54:01:
There is supposed to be a drain valve in that hole. They usually look like the same part you use to drain the radiator. No hose unless you want to stick one on there temporarily to direct the flow to a bucket.
