Re: Results with Draft control
Posted by Larry on May 03, 2018 at 07:46:23 [URL] [DELETE] :
In Reply to: Results with Draft control posted by Kimberly on May 02, 2018 at 16:43:11:
I've never liked draft control. Plowed acres of ground for many years with a Ford 4000 1963 with a 3 bottom plow. We had a large muck field also. It seemed draft control pushed the plow to deep. I would set the plow at the proper depth and take off. If the tractor started to lug I'd lift a plows up a tad. Doing something as small as a garden don't use it just set it and go.
