Re: Steering Box
Posted by Tim Daley(MI) on May 01, 2018 at 16:51:41 [URL] [DELETE] :
In Reply to: Re: Steering Box posted by Kimberly on April 30, 2018 at 13:00:54:
Yes, the red line mark is the correct lube port, but getting oil in there can be messy too. With the modified hex bolt with Zerk fitting, you then use a grease gun filled with whatever you want - oil or cornhead grease, and a lot less messy. Like I said, a worn out box isn't going get better just by adding lube.
FORD 8N LATE STEERING BOX LUBE PORT AS MARKED WITH MODIFIED HEX BOLT & ZERK:
