Re: Steering Box
Posted by Tim Daley(MI) on April 30, 2018 at 08:35:02 [URL] [DELETE] :
In Reply to: Re: Steering Box posted by Kimberly on April 21, 2018 at 17:36:28:
No, that is not the plug -your previous photo marked in blue. It is higher up the shaft I think, I'm trying to remember. Should already be a 7/16-14 bolt in it now. If you can't find it, like said early on, the original manual says to remove acorn nut and pour oil down steering shaft. You'll find out in a day or so if the seals are shot as the oil will just weep out all over and you'll have a mess. Any lube is better than no lube, but, once bearings and bushings are worn, no amount of lube is going to help.
