Re: 9N coil
Posted by Tim Daley(MI) on April 28, 2018 at 14:10:19 [URL] [DELETE] :
In Reply to: Re: 9N coil posted by Les Leach on April 28, 2018 at 12:17:58:
First, you can't post picture for free anymore from PhotoBucket unless you "upgrade" your account and pay $500 per year. Some of us use www.imgur.com now as it is still free.
Next, this is what was said about the resistor:
"...you need the original ballast resistor with both the 6 volt and 12 volt coils. What you do not need with a 12 volt coil is an extra resistor in the wire going to the coil. Look at JMOR's pictograms to see that the original ballast resistor is used in both/all setups..."
Scroll down to the 4th diagram -9N/2N 2-volt conversion and observe the diagram closely. So, first is to answer us this. Is there an OEM Ballast resistor in place? We've posted pictures and the pictograms have sketches of what it looks like.
