Re: 9N coil
Posted by R Geiger on April 26, 2018 at 16:11:43 [URL] [DELETE] :
In Reply to: Re: 9N coil posted by Tim Daley(MI) on April 26, 2018 at 16:03:53:
you need the original ballast resistor with both the 6 volt and 12 volt coils. What you do not need with a 12 volt coil is an extra resistor in the wire going to the coil. Look at JMOR's picograms to see that the original ballast resistor is used in both setups.
