Re: 8N starter button
Posted by R Geiger on April 18, 2018 at 15:34:54 [URL] [DELETE] :
In Reply to: 8N starter button posted by Jim on April 18, 2018 at 14:54:05:
You most like will need to replace the solenoid as well. the original push button switch just provides a ground for the wire that runs from the small terminal on the solenoid to the switch. a key switch type solenoid most likely needed power applied to it to operate. google 8n wiring by JMOR and chose the one for your tractor.
