12v ign system voltage & resistance test?
Posted by Rusty 2N on April 09, 2018 at 12:41:30 [URL] [DELETE] :
I have searched and can only find instructions for doing a 6v system, this is 12v. Seems to be going through points.1950 8n side mount. I know the condensor is spose to help prevent this. So I need to make sure all ohms and voltage is correct going through this system. Had a Falcon do this to me once and it turned out to be a shorted wire behind dash. Checked all the wires, all good there. So I figure if I test to make sure all is right before I start just throwing parts at it.
I will go over it all again and again till I figure this out. But need the process and correct readings to do it right.
Any help, advise, pointer will be appreciated. Thank you Rusty
