In Reply to: Re: naa hydraulics posted by TheOldHokie on April 08, 2018 at 20:40:30:
we cleaned out the manifold lines and used new o rings, new piston o ring and back up washer. we did use a cylinder from a donor rear end because mine was gouged pretty bad. like i said in the first post it worked a few times after running for a while. but now nothing, the pump has to be turning it has no choice. so in your opinion would you start with rebuilding the pump?
