Re: naa hydraulics
Posted by TheOldHokie on April 08, 2018 at 20:40:30 [URL] [DELETE] :
In Reply to: Re: naa hydraulics posted by Doug on April 08, 2018 at 19:16:36:
The proper place to test pump pressure is at the test port on the side of the centr housing. Pressure of around 2000 PSI. But if you aren't getting flow you will not get pressure. First order of business is to get flow.
TOH
