Re: naa hydraulics
Posted by Doug on April 08, 2018 at 19:16:36 [URL] [DELETE] :
In Reply to: Re: naa hydraulics posted by TheOldHokie on April 08, 2018 at 06:12:59:
It did not have this problem before we put a new piston in. I pulled the side cover off today with the tractor running moved the position control. The ram arm moves but the piston does not. I bled the pump and still nothing. When we drained the system there was a lot of water, maybe something with the pump itself. I want to try an put a pressure gauge on the bleeder of the pump. What should the psi of the piston pump be?
