Re: naa hydraulics
Posted by TheOldHokie on April 08, 2018 at 06:12:59 [URL] [DELETE] :
In Reply to: naa hydraulics posted by Doug on April 07, 2018 at 18:32:53:
Your problem is not the oil - your problem is a pump that will not prime. Possible causes:
  • Air leak or obstruction in the hydraulic suction line
  • Badly worn pump
    Did you have this problem before you did the other work?
    TOH
