Re: Starting issue
Posted by Jack - Iowa on April 04, 2018 at 14:06:55 [URL] [DELETE] :
In Reply to: Starting issue posted by BrianS, NE on April 04, 2018 at 09:23:58:
Sounds like the solenoid is buzzing due to low voltage. I have had battery cables which looked just fine but which were corroded inside the end termination. Check your battery but be sure and check EACH cable termination from the battery to the solenoid. Also check the ground path from the solenoid clear back to the battery. A weak link anywhere in the chain and the chain is no good.
Good Luck,
Jack
