Re: 9N PTO clutch stuck on.
Posted by Mark on February 13, 2018 at 11:11:33 [URL] [DELETE] :
In Reply to: Re: 9N PTO clutch stuck on. posted by Lynn Patrick on February 13, 2018 at 09:14:38:
Pin is 5/16,,,mic'd out at .322 or so. I sprayed it down in there good with penetrating oil and tried the smaller punch with the pto in gear tapping on it pretty good...no movement yet, so I soaked her down as good as I could...can't really get behind it very well so most of the penetrating oil I'm putting down the grease zerk holes and I just spin it around and try and nozzle it into the area the pto shaft is in. I think there is only one pin as I can see the holes turning good straight through. Thanks for the advice...I'll let her soak and try again tomorrow. For now I removed the battery which had a 05/12 sticker on it...even though it's working now, I plan on replacing it before long as it probably doesn't have long...it's a Walmart Maxx. Upon removing it I saw a big dirt dauber nest on the top of the air cleaner so I think I'll go work on that now. At least it's under a carport so I won't get wet as it's raining her near San Antonio.
