Re: Stabilizer bar question
Posted by Tim Daley(MI) on February 12, 2018 at 07:01:31 [URL] [DELETE] :
In Reply to: Stabilizer bar question posted by Mark on February 11, 2018 at 23:47:24:
Mark,
The dimension is something like 31"-32" so wherever you are measuring from isn't right or you have aftermarket lift arms. Measure from center of ball socket on lift arms to center of hitch pin on diffy case where lift arm fastens to. EBAY isn't the best place to buy many parts from as sellers usually have no clue and sell in bulk for all makes and models. There are a handful of reliable Ford Tractor parts suppliers: Dennis Carpenter; Just8Ns; STEINERS; Grand Valley; et al. SEE LINK BELOW. The fender brackets with hitch pin is set as described below. The pins must face inward toward the lift arm pins face to face. Do this: take your hands and make 'pistols' with the thumbs pointing downward and th index fingers pointing towards each other. The new aftermarket kits have brackets with a series of position holes for the pins because they can fit many different tractor models. You will need to get longer 5/8-18 x 6-1/2" long hex bolts to fasten the brackets to the bottom of the fender bosses. You set the brackets loosely under the fenders and determine which holes match your 9N pins, then fasten the new hitch pins onto the brackets and tighten. Leave fender brackets in place loosely. The next step will be to set the brackets permanently. Take an implement like a back blade or plow or mower. Hitch it to your lift arms. Then, take one stabilizer bar and connect it to the fender bracket LINK PIN and fasten a Linch Pin on it. next take th loose end of the bar and slip it onto the implement LINK PIN. This may take some physical positioning to get it to fit -that's why you left the fender brackets loose. Once you have both ends secured with Linch Pins, do the other side the same way. Keep fender brackets loose until you test the lift action and are certain there i s no binding or bending of the bars. Once you get the stabilizer bars set, they are good to GO for ANY 3-point implement you attach and there is no need, not recommended to muck with them ever again. There were original brackets made and stabilizer bars. the brackets were designed with one Link Pin so there was no guessing as to where it should be. Once fastened on the fender, the Link Pins aligned perfectly. Then it was only a matter of setting the bars correctly as described above. We have a procedure for setting stabilizer bars in our HOW-TO's forum -click on the subject from the red menu bar at the top of the homepage on this site.
FORD TRACTOR ORIGINAL STABILIZER BRACKETS:
ORIGINAL DEARBORN STABILIZER BRACKETS, (top), & AFTERMARKET STYLE, (bottom) SHOWN:
NOTE: The original DEARBORN RH bracket as shown contains a ball socket that was used on the rear mowers.
FORD 8N w/AFTERMARKET STABILIZER BAR KIT SETUP:
