Slow cranker
Posted by Tom on February 04, 2018 at 18:56:58 [URL] [DELETE] :
My 901 gas job cranks real slow. It has a fresh battery (12V conversion), new battery cables, and new starter cable. I've cleaned all the connections, switched to lighter weight oil, added a block heater and it barely cranks fast enough to start at 30 degrees. Any suggestions? Could the starter be worn out? Adding a jumper pack doesn't seem to speed it up much.
