Re: 6 volt alternator
Posted by JMOR on January 26, 2018 at 09:50:38 [URL] [DELETE] :
In Reply to: Re: 6 volt alternator posted by AL CT on January 26, 2018 at 09:31:59:
Dim lights. If the bulbs do not draw more than the generator output, then I do not believe an alternator will make them brighter. If they draw more than the generator output, then the ammeter will be reading discharge, as some of power will be coming from battery. If such case, I would verify that correct bulbs are installed (no so called 'upgraded' bulbs) and that the generator is capable of its rated output. Also, that the VR is regulating to the specified voltage.
