Re: Jubilee dies when a load is put on the PTO
Posted by Bruce (VA) on January 24, 2018 at 13:06:16 [URL] [DELETE] :
In Reply to: Jubilee dies when a load is put on the PTO posted by Byron on January 24, 2018 at 12:46:31:
You just rebuilt the carb and you don't know how to adjust it?
6 volt or 12 volt?
Donít guess at the cause of the problem; guessing can get expensive. And leave you breathless chasing every guess.......it could be this, it could be that......just troubleshoot the problem and leave the guess work for buying Lottery tickets.
As soon as the tractor stops running, not 5 minutes later, check for spark and fuel.
You need to answer 2 questions before you do anything else:
With the bolt in the carb bowl removed and the gas on, will the fuel flow fill a pint jar in less than 2 minutes?
Next, get out your adjustable gap spark checker * , open the gap to 1/4", hook it up, turn the key on and crank the engine. Does the spark jump 1/4"? Post back with the answers.
* Don't own an adjustable gap spark checker? Buy one! Not a test light! Until then, take an old plug, open the gap 1/4" ground it to the head & look for spark. Itís not the color of the spark that counts; itís the distance it jumps. https://www.amazon.com/AMPRO-T71240-Energy-Ignition-Tester/dp/B00A8FO87S/ref=sr_1_fkmr1_4?ie=UTF8&qid=1513273147&sr=8-4-fkmr1&keywords=ampro+spark+checker
