Re: 1940 9N starter relay question
Posted by deanostoybox on January 23, 2018 at 17:51:17 [URL] [DELETE] :
In Reply to: 1940 9N starter relay question posted by Serge on January 22, 2018 at 18:44:29:
Hi again
Just read my reply to your post and something did not make sense. You said you hooked the + post on the battery to the starter, and the - post on the battery to the frame. Do you not have a cable or strap connecting the - post of the battery to the frame? If it is 12V negative ground you should. Putting the jumper from the + post of the battery to the starter should bypass the switch and it should crank without needing a jumper cable from the - side of battery, that should be connected already.
later
deano
