Re: 52 8N Hydraulic Lift Handle Sliding Down
Posted by 36 coupe on January 23, 2018 at 05:46:00 [URL] [DELETE] :
In Reply to: Re: 52 8N Hydraulic Lift Handle Sliding Down posted by Mike D on January 21, 2018 at 21:07:37:
Relacing the friction disc is not easy.The die cast part the handle bolts on to will be stuck to the shaft.I had to use a puller on the last one I replaced.The part breaks easy and can cost 30 bucks.
