53 NAA
Posted by Doug on January 08, 2018 at 22:31:40 [URL] [DELETE] :
So we tried to get the axle nut off the NAA this evening, no luck. We had a bar between the studs with lug nuts on so we didn't ruin the threads and wrench on the nut with a black iron pipe and we did nothing but bend the bar. I sprayed it with PB Blaster and we also used heat. No luck, is there a trick we are missing? I may try putting he wheel back on and using a 3\4" drive impact. Any suggestions?
