Re: 9n wont start
Posted by Torch on January 07, 2018 at 22:02:26 [URL] [DELETE] :
In Reply to: Re: 9n wont start posted by Bruce (VA) on January 07, 2018 at 15:25:33:
Just to clarify whats going on. Switched over to a electronic ignition and 12 volt system which is all new and done according to instruction. A brand new battery. I checked it out tonite and it has spark and gas but wont start. The governor arm that goes to the carb butterfly is very tight. When I move the throttle lever it does not move the carb butterfly at all. The carb butterfly is always in the idle position.
