Re: Positive Ground Location
Posted by R Geiger on January 02, 2018 at 21:13:22 [URL] [DELETE] :
In Reply to: Positive Ground Location posted by Tony Sanchez (OR) on January 02, 2018 at 19:54:34:
I use the braided ground straps for the ground. Do you have a wire ot strap? What size is the wire if you are using a wire? In any case it should not get hot, either too small corrosion or loose connection. nothing says you cannot use a longer strap.
