Re: Electronic ignition
Posted by Nic on January 02, 2018 at 16:17:20 [URL] [DELETE] :
In Reply to: Re: Electronic ignition posted by K.LaRue-VA on January 02, 2018 at 15:41:21:
I am inside, thank goodness. The plug wires are in the right way, that is not it. So I pulled distributer and set flywheel to 0 degrees, reinstalled dist and put flywheel at 8 degrees,rotor pointing at cylinder 1 wire. Not starting, clearly I am missing something. Not a mechanical whiz, not a novice either.
