Re: maintenance
Posted by Kirk-NJ on December 29, 2017 at 10:28:45 [URL] [DELETE] :
In Reply to: maintenance posted by Doug on December 29, 2017 at 09:55:02:
6volt will be ok if you're wiring is good, strong battery with right size cables and good compression and good tune up parts. Block heater will probably help if you have straight 30W oil.
Have a bunch of 6 volt tractors that run all winter
Kirk
