Re: lift pin leaking question
Posted by Farmer Brown on December 23, 2017 at 06:56:17 [URL] [DELETE] :
In Reply to: lift pin leaking question posted by 2NTony on December 20, 2017 at 10:41:22:
I had the same problem, same side with my 9N. The pin loosened and must have sheared the inside cotter pin. I had a leaking PTO shaft at the same time. I was able to get my arm in the big hole where the pto shaft was and get a big box wrench on the nut. I had a helper torque the heck on the stud. The stud is still tight and leak free.
