Re: hard starting
Posted by Doug in Maine on December 19, 2017 at 22:57:09 [URL] [DELETE] :
In Reply to: Re: hard starting posted by K.LaRue-VA on December 19, 2017 at 22:45:13:
I've wondered if my starting technique should be different with 12V. I don't usually do full throttle/choke. At times with this tractor I've been able to start it with no choke in warm weather with 6v. Typically I use maybe 2/3 throttle, let it spin a bit, then add choke and it would start right up. Carb is adjusted with manual suggested one full rev out on both jets. Could it be a carb adjustment? Too rich? Could it be a weak charge on the battery? The spark is a nice hot blue/white. It's 38 degrees - this thing should fire right up.
