Re: oil,filter canister
Posted by Tim Daley(MI) on December 17, 2017 at 19:56:14 [URL] [DELETE] :
In Reply to: oil,filter canister posted by cage on December 17, 2017 at 18:10:38:
Well if you bought parts for a TO tractor, chances are they won't fit. The TO model is a Ferguson tractor, not the Ford 9N or 2N model. If indeed you have s/n 9N -6637, it is an early model, first year produced, 1939. The early 9Ns had no oil line feeding the governor either but later governors had a line piped on and fed back to the oil canister. Try Just8Ns for the correct oil lines, pre-cut and fitted exact. I have my grandfathers early '39 9N Ford-Ferguson *9N-653I* s/n so we would be real close in engine block assembly and approval.
Tim *PloughNman* Daley(MI)
*9N653I* & *8NI55I3*
