Stuck clutch
Posted by Kirk-NJ on December 11, 2017 at 08:40:50 [URL] [DELETE] :
I have a few tractors that don't get uses over the winter that sit outside under a tarp. If you have the same I'd like to remind you to block down the clutch pedal so in the spring when you need your tractor you don't wind up with a stuck clutch.
Kirk
