Re: Trouble shooting
Posted by BlasterStumps on December 10, 2017 at 13:39:36 [URL] [DELETE] :
In Reply to: Trouble shooting posted by Mike Stanaway on December 10, 2017 at 12:51:32:
Hi Mike,
How much checking of fuel flow have you done so far? There are screens. I believe one is on the fuel shutoff up inside the tank, one inside the fuel shutoff sediment bowl (flat screen) and one on the elbow that goes into the carb. Not sure if the 2N has all this but there is a good chance that is what you have. Need to make sure they are all clean and that fuel will flow freely to carb. Should be able to check the flow by removing the plug on the bottom of carb and let it run into a container. I don't have a 2N so I am repeating advice for my 8N.
Mike
