Re: Newbie needing help
Posted by Bruce (VA) on December 03, 2017 at 09:15:56 [URL] [DELETE] :
In Reply to: Newbie needing help posted by Ben Morrow on December 03, 2017 at 00:32:45:
You have an 8N. Follow the link Bruce (OR) attached for more info.
Re " Needs carb. , starter and right side drawbar w/adjuster." you will be much happier to have oem parts rebuilt. Iíve been working on old cars, trucks & tractors now for over 50 years. Whenever possible, I get OEM component parts rebuilt. Given the high probability that any new component part purchased for an N tractor is made somewhere overseas w/o adequate quality control, chances are very good that you will be disappointed. If you do not have a local rebuild shop, give these guys a call for a quote & shipping info:
Automotive Manufacturers Inc
2400 N Lombardy St Richmond, VA 23220
(804) 321-6861
They do mail order work. They rebuild carbs, clutches, pressure plates, water pumps, alternators, generators, starters & reline brakes.
These guys should be able to help you w/ used parts:
John Smith smith8N@att.net
Rod Mondor at Forest Lake Tractor fltractor@peoplepc.com or 651 464
4628
Ken at Long Lane Tractor lltractor@embarqmail.com or 717-367-8610
For new parts, I use Just8N's or Dennis Carpenter.
The first thing you will need i a set of manuals; see tip # 39 at the link as well as the "How-To's" at the top of this page.
And lastly............. do not buy a new part for the tractor until you can answer this question: how do I know the part on the tractor is defective?
