Re: 3 pt lift response
Posted by deanostoybox on November 27, 2017 at 22:43:59 [URL] [DELETE] :
In Reply to: 3 pt lift response posted by BrianS, NE on November 27, 2017 at 19:32:57:
I can imagine a chunk of something buoyant in oil inside the cylinder too big to fit in the passage that will let oil enter, but when the pressure is released it rushes to the hole and stops it up partially so the oil leaks slowly out. I cannot imagine that is very likely though:-) More likely something to do with the linkage adjustment not letting the exhaust valve open completely. Does it exhibit the same behavior in both draft mode and position control mode?
