Re: 3 pt lift response
Posted by Charles Krammin on November 27, 2017 at 21:27:24 [URL] [DELETE] :
In Reply to: Re: 3 pt lift response posted by Brian's, ne on November 27, 2017 at 21:05:22:
I would check the spring that between the piston and fork as it is what forces the release valve in. could be weak. Put your hand trough the access hole of sideplate and shove the fork in and see if it goes down fast that way.
I'm sure you got the fork attached at both side of the fork?
Charles Krammin
