3 pt lift response
Posted by BrianS, NE on November 27, 2017 at 19:32:57 [URL] [DELETE] :
OK. So I have been fighting this for a while. I realize the best solution may have been to tear the pump apart and start fresh, but didn't get it done.
Background. 8N, lifts strong, not much leak down.
Issue is very slow dropping when I want it down. Last year, I dropped the pump, cleaned really well including a bath in diesel. I also replaced the exhaust valve spring after consultations with folks here.
Put it all back together, and nothing changed. I ran out of time and had to get ready for winter and suffered through it.
I have a second 8N which had no issues. My thought was to just swap the pump into my worker and then work on the removed pump as time permitted.
As you can guess, the pump from #2 put into #1, the worker that had the issue, is exhibiting the same slow drop.
My question is, is there somewhere else in the "plumbing" that could be causing the slow response to drop the implement?
Am I making an sense?
Thanks guys.....
