Re: 860, anyone seen this PS before?
Posted by Todd in WI on November 26, 2017 at 12:16:20 [URL] [DELETE] :
In Reply to: Re: 860, anyone seen this PS before? posted by SelectOSpeed on November 26, 2017 at 08:11:33:
Thanks for the clues guys!
It's definitely not farmerized, the mounting loop at the base of the axle brace is very cleanly done, the pump bracket was bent and punched with heavy tooling, and the reservoir bracket on the rocker cover is professionally welded.
From what little I can find on the old CharLynn systems the steering shaft has been butchered, the steering box refuses to hold any lube, 'notches' and binds.
Right now I'm seriously considering nuking the whole mess and scrounging up a different box and column.
