1950 8N Rear Two Seal Axle Bearing Lubrication
Posted by Keg on November 25, 2017 at 10:38:30 [URL] [DELETE] :
I have been thinking about an upcoming repair on my axle seals on my 1950 8N.Thinking about the design changes which included an inner and outer axle seal.How was the outer axle shaft bearing intended to get lubrication after the design change?I have seen posts that say the bearing should be greased, others say the gear oil does the lubrication.
