Re: 9n starting problem
Posted by steveVa on November 22, 2017 at 18:26:59 [URL] [DELETE] :
In Reply to: 9n starting problem posted by Carl on November 22, 2017 at 15:42:53:
Could be a dead battery, could be a bad solenoid, could be a bad starter. Could be a bad starter switch. Did you try jumper cables? Jump the solenoid? Check the battery cables, check the main ground. Check the starter. Check back...
