Re: 9n starting problem
Posted by Bruce (VA) on November 22, 2017 at 16:44:29 [URL] [DELETE] :
In Reply to: Re: 9n starting problem posted by Carl on November 22, 2017 at 16:33:22:
If it was running and stopped, and the battery will not turn the starter over when you press the starter button, that tells you that the battery is no longer electrically connected to the tractor. Get out your meter and start looking for the absence of battery voltage. HINT: check the connection between the negative battery post and the tractor chassis first. If you have trouble tracing the circuit, check the wiring diagrams in the "how-to's".
