Re: Fuel Cut Off Valve
Posted by JMOR on November 20, 2017 at 10:59:01 [URL] [DELETE] :
In Reply to: Re: Fuel Cut Off Valve posted by Bruce (VA) on November 19, 2017 at 18:09:57:
Naaah, Bruce, build a custom rotary joint set up to supply air path from center of spindle to tire valve stem and add engine driven compressor/regulator system so as to keep tire inflated even with a leak (ala Humvee). :)
