1948 8n starter
Posted by John McQuaid on November 18, 2017 at 16:54:51 [URL] [DELETE] :
Hello, my starter is only about two years old. The rachet style drive failed on the tractor engaged to the flywheel. I removed the drive and retracted it AND reinstalled. When I bench test the starter it spins but does not pull in to engage. Does this mean the drive is bad or does it need to be installed in the tractor to work properly?
John
BTW I found the precudure on utube to unretract the drive.
