Re: Coil or condenser
Posted by 36 coupe on November 16, 2017 at 20:53:52 [URL] [DELETE] :
In Reply to: Coil or condenser posted by BeanStalk on November 12, 2017 at 18:20:25:
A condenser can be tested with voltage apllied to it.Old stock condensers can tested for leakage and loss of capacity.Many will have leakage and cant hold a charge.Some develope a loose connection or absorbe moisture.I have had a model A ford that stalled after traveling a quarter mile.It seemed like it was running out of gas but started after cooling a bit.It stalled back home.A new condenser fixed it.If you get 5 sparks then none, change the condenser.I started working on Fords in 1950 so I know a bit about them.
