Re: 8N oil pump
Posted by 36 coupe on November 16, 2017 at 20:32:27 [URL] [DELETE] :
In Reply to: 8N oil pump posted by George Peebles on November 16, 2017 at 10:55:41:
These gears have 2 prefixs in their part numbers.One is 52 another 9n.Called drive and driven.They may have a different width.The 52 is from the 60 hp Ford V8.The 60 engine was first used in 1937.I cant see how you can turn a pump fast enough bby hand.Oil flows around the out side of the gears.Side wear on the gears will give trouble.
