Re: Coil or condenser
Posted by Bruce (VA) on November 12, 2017 at 19:36:52 [URL] [DELETE] :
In Reply to: Coil or condenser posted by BeanStalk on November 12, 2017 at 18:20:25:
" does the coil provide the spark or the condenser "
Neither one.
The battery provides the spark. The coil just amplifies it.
Charge your battery.
Then, check your spark.
Donít guess at the cause of the problem; guessing can get expensive. And leave you breathless chasing every guess.......it could be this, it could be that......just troubleshoot the problem and leave the guess work for buying Lottery tickets.
Get out your adjustable gap spark checker * , open the gap to 1/4", hook it up, turn the key on and crank the engine. Does the spark jump 1/4"? Post back with the answers.
* Don't own an adjustable gap spark checker? Buy one! Not a test light! Until then, take an old plug, open the gap 1/4" ground it to the head & look for spark. Itís not the color of the spark that counts; itís the distance it jumps.
