Re: Coil or condenser
Posted by clayton ingmire on November 12, 2017 at 19:07:45 [URL] [DELETE] :
In Reply to: Coil or condenser posted by BeanStalk on November 12, 2017 at 18:20:25:
The coil delivers the spark, when the points are closed it builds its charge then releases it when the points open the condenser helps control points from arcing out it helps control voltage to the points you said you replaced coil did you get a 6v or maybe the 16 year old behind the counter handed you a 12 volt look on the coil it will be marked
