Re: 9N or 2N ?
Posted by Bruce(OR) on November 11, 2017 at 15:25:48 [URL] [DELETE] :
In Reply to: 9N or 2N ? posted by Tony Sanchez [OR] on November 11, 2017 at 12:02:55:
Fun part comes when you decide you like position control hydraulics that the 8N has.
That can be done with a donor 8N and swapping the pump and top cover. Once you get the 8N, you will probably find it in too good a condition to become a donor.
then begins the slippery slope. After the second tractor, you finally figure that each implement should have it's own tractor to eliminate the time changing things over.
Only one machine so far??
Once you get it restored you can probably get it into the local July 4 parades and such. Steam up in Brooks in July/August. Might see you there. . .
