Re: Newbe with a 9n
Posted by Bruce(OR) on November 08, 2017 at 21:39:05 [URL] [DELETE] :
In Reply to: Newbe with a 9n posted by Tony Sanchez on November 08, 2017 at 13:26:59:
The wife started me with a 9N. The next one was a Fergy TO-20 and that was followed by several others. Mostly Fords. If your machine is 6V Pos ground, hook the 12V jumper cables from donor veh pos to the ttractor foot peg (works as a good ground) then touch the neg cable to the starter, partial throttle, key on, out of gear, out of gear, run the choke and it should start once all the repairs are all done.
I am outside of Hillsboro in the hills.
