Difference between fender mountd 8N to Ford 600 ?
Posted by Charles Krammin on November 01, 2017 at 11:56:12 [URL] [DELETE] :
Tim Daley
In mounting a Dearborn 14- 16 mower on a Ford 600,you stated the fender mount "breakaway" were different measurement front to back. I want to put washer under the mount to move the attachment point ahead. Would 3 washer do it or what would be the different measurement, to the breakaway mount point.
I could also change the threading on the break away rod to get the 1/2"/ ft length lead , on the end of the blade per foot of length of the blade ( 7' blade = 3 1/4").
Doing it by washers would retain the mower to fit either N's or 600.
I use an adjustable sway bar on the left which accomadates Ns or 600.
I made longer extensions for the 600 lift rods, but it would have been easier to extend the top link slide hole to accomadate the higher lift length of the 600.
Thanks
Charles Krammin
